AK-C
- Joined
- Jul 10, 2014
- Messages
- 3
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
Seller is original owner of this boat. Bought new in 2005 and trailered up to AK. The boat, motor, trailer and all equipment are in excellent condition. The Alaskan sun (or lack of it) is kind on equipment and everything has been well maintained. The boat doesn’t have an hour meter but estimate about 50-60hrs(much at hull speed) average per season since 2005. The motor has been flushed after every outing, winterized every fall, and oil/foot lube changed at start and end of each season. Authorized Suzuki shop did tune up and compression test May, 2013.
The trailer bearings each get half a dozen shots of grease after every launch/haul via the King Trailer “super lube” system. The bearings were professionally replaced at the end of the 2012 season after 7500 mi. and upward of fifty launches. The axles and removed bearings still looked perfect. The trailer does need a brake job.
Will get some photos posted soon.
Exterior:
o Suzuki 90hp outboard w/permatrim.
o Stainless prop plus two spares: original aluminum(never used) and piranha 4 blade(plus spare set)
o Twin 24 gallon fuel tanks, tank selector switch, racor fuel filter/separator
o BayStar hydraulic steering
o Lenco trim tabs
o No bottom paint (never left in water more than a couple of days)
o Full canvas bimini/enclosure with five removable panels (excellent canvas work)
o Factory cockpit floorboards
o Delta anchor bow mounted with 30 feet of chain and 300 feet of 3 strand nylon rode
o Batteries: house/starting w/selector. Batteries have couple of seasons on them.
o Electric and manual windshield wipers on helm side, manual only on port side
o Stainless radar arch with four rod holders
o manual bilge pump aft, electric pump midship(standard spot)
o swim step
o kicker bracket
o cooler mount in motor well
Interior:
o 20gal fresh water tank
o Stainless steel galley sink with foot operated pump
o Wallas galley stove/heater combo(2008 model w/low hours), burns either diesel, kero, or kleen heat
o Dinette converts to sleeping berth
o V berth forward under cuddy
o Opening side windows, windshield center panel and bomar hatch in cuddy over v berth
o Porta potty
Electronics:
o JRC 16 mi. radar
o Hummingbird fishfinder
o VHF
o Ritchie compass
Trailer:
o King bunk style tandem axle trailer w/surge brakes(disk brakes on both axles)
o carpet installed over the plastic slides to reduce bottom gelcoat chaffing
Extras:
Also have a 2010 Yamaha 8hp high thrust kicker, electric start, hydraulic tilt, controls/steering from main helm. If desired will include kicker(installed) in sale for total price of $42,500.
Exterior:
o Lenco trim tabs
o swim step
o kicker bracket
Interior:
o Porta potty
Electronics:
o JRC 16 mi. radar
o VHF
o Ritchie compass
Trailer:
Extras:
