Well-known member
- Joined
- Nov 7, 2003
- Messages
- 7,984
- Reaction score
- 26
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
finally go to work on the 27 some more. I found three places where the water was leaking in. On the port side where the hull and the cabin are jointed water was leaking thru the old caulking and down the wall. I have drilled out the last two rivets on the cab and will clean the surfaces and reattach with 5200 and new rivets. I was amazed to find that he rivets are the only thing holding the hull and cab together. the bead of caulking along the joint is only at the joint and was applied after the two parts where joined.
Also both fuel caps are leaking and running down the hose into the hull. I have one fuel fill pulled out and I found unsealed core wood. After 27years of use the soft wood only penetrated about a 1/4 inch to 1/2 inch. I routed it out and filled the whole thing with epoxy.
I have also removed all the old fuel and over flow hoses. The flange that tightened the over flow vent had rusted into a pile. So that got pulled out. All the stainless hose clamp's where ok but the screw that tightens down the clamps where all crumbling. This will all be replaced.
I have decided against having the rear bulk head replaced with fiberglass. There is no rot in the starboard wall so I don't want to pull it out. I also don't want to have only one fiberglass wall and one wood wall so I am replacing rotten one with another wood wall. What would be the best way to treat the wood? which type of paint? I will be using marine grade ply.
