Well, I finally finished fixing up SeaDNA for sale today. It took longer than I had anticipated since I took the time to replace all the L-brackets that were screwed into the floor with fiberglass tabs. The process was as follows:
1) Rough up the floor and wood with 200 grit sandpaper.
2)First mix up some duraglass putty and push it into the corner where the tab will go later. Used either my finger or a rounded end of a stir stick to create a fillet (rounded corner out of the duraglass). Let it cure for a day.
3) Cut 2" squares from fiberglass tape. I used a 2" wide tape and I cut 2 squares for each bracket I replaced.
4) Mix West systems resin as directed on the containers after I did the first few, I mixed some white pigment in to make it look a little prettier.
5) Coat two pieces of the fiberglass on both sides with the resin an press the two pieces (one on top of the other) into the corner. Smooth out the glass with a putty knife (or you fingers if wearing gloves).
6) Allow to cure.
After painting out the floor with the grey paint here's one a fiberglass tab looks like. This is a top view of one that is under the water tank (under the aft port side seat).
I also got around to fixing the wobbly table. I bought two pins that are 1/8" in diameter, 1/2" long and which have a spring loaded ball bearing in one end and a split ring on the other. I then drilled out the angle bracket on both sides of the table to allow the pin to slip in. The ball bearing retains the pin and the pin retains the table in the mounting brackets. Here's an image of the system.
I've now fixed everything that was either wrong or which annoyed me over the past 8 years. Amazingly, I could over look these little things for a long time but one I decided to sell, I had to fix them. Of course, Joyce asked why I didn't fix the darn table years ago... :lol:
