Doryman
- Joined
- Oct 3, 2006
- Messages
- 3,807
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 255 Tomcat
- Vessel Name
- Lori Ann
drjohn71a":1vl1727v said:Well, I routinely use that cleat just ahead of the cabin helm window. I keep lines looped over those cleats port and starboard with the free ends ran back and loosely tied to the boarding handles on the aft cabin corners. Those work well for me. You can tie those forward lines to a shorter aft cleat line and then loop that around a couple of cleats as you step off while docking.
I have figured out the same thing about the forward cleat -- I run a line aft on each side and tie them to the handles. Some of the Brats use a jam cleat for that purpose.
I am not sure I understand how you tie the aft line to the forward line. are you saying you tie it on so that after you step on the dock you can untie the aft line from the forward line and tie it to another cleat? Why not just take both lines in your hand after you wrap the forward line around the dock cleat and then step off with both lines? (I am too chicken and not agile enough to step off a boat that is not secured to the dock.)
