side nav lights
triton1
Oct 25, 2007
60
I have a 2006 c-dory 25. What manufacture supplied the side nav lights on my model c dory. Does anyone know the exact model number. Has anyone had internal moisture problems with them? Thanks.
Perko lights?
and yes, they get "wet" inside.
I found water in my perko nav lights also. Pulled them & found the rubber seals were dried out & cracked. I had a tube of "Big Stretch" made by Sashco & purchased at Ace hardware that I use around the house for many sealing jobs. I wiped down the cracked seals with lacquer thinner & laid a thin bead of big stretch on top of them, let them dry a few days until fully cured reinstalled them. Problem solved cheaply! Vern
