SI-TEX Marine Radar Model T-100
daisyleal
Nov 5, 2012
1
We turn it on and warm it up and the only thing that happens is a straight green line in the middle of the screen
The radar dome up top is spinning after we took the lid off
What do you think is wrong with it
Please help
Daisy
Daisy, talk with TUG. He had one and went through a lot with it before he replaced it. He may still have it if you'll eventually need parts. Look here...
http://www.c-brats.com/viewtopic.php?t=13904
Good luck,
Please help
Daisy
Call SI-TEX?? :wink:
I've had experience working with older aircraft radar. The symptom you describe is the antenna position sensor is no longer telling the screen its position. PROBABLY a cable connection between the antenna and the display. Check for anything loose or corroded. It could also be a BAD position sensor and you could be talking big parts and labor bucks to replace or fix that.
