Shower sump
Look under the port side hanging locker. There is a "false floor under the bottom of the locker. There should be a shower sump discharge hose in the same area, which leads out the port side of the hull, above the water line.
What is there depends on the year--some may also have a water intake for the raw water wash down there. You can follow the
My sump was under the hanging locker as well. There were 2 boards which had to be pulled up. It was in a plastic box with a pump and several hoses running into it.
My raw water intake was under the step in the cabin. There was a pump in there too.
