Seat set up for short legged, long torso person.
  • Thread starter Thread starter Anonymous
  • Start date Start date
A
Anonymous
Guest
The seat set up in our 19’ must have been designed for a short legged, long torso person. Also, as the seat turned it wore on the cushion behind it.
The obvious solution was to raise the seat, it took a while with several options, but finally came to the easiest way (for us) was to purchase a 7” Attwood Economy Pedestals from Cabela’s and have our local machine shop cut it down to 3” high.
For Connie’s seat, the 7” Economy pedestal was cut down to 4” which worked best for her.
Thought the information would help others that are personalising their C-Dory’s.
Regards,
Ron Fisher
http://www.c-brats.com/modules.php?set_ ... _photo.php
Ron, good stuff!
You can embed the images into the post if you open the photo, right click on it, then select "copy image address" (Apple).
Then press the image button, paste in the address and hit image again... It looks like the code below. I put spaces inside the brackets here to keep it from displaying.
[ img]http://www.c-brats.com/albums/Lil-Sis/seat05.sized.jpg[ /img]
Here's the result...
