Marco Flamingo
Active member
- Joined
- Jul 9, 2015
- Messages
- 1,179
- Reaction score
- 8
- C Dory Year
- 2004
- C Dory Model
- 16 Cruiser
- Vessel Name
- Limpet
Jackie,
Now I see how your seat boxes are installed. On mine (2005) the seat box flanges were riveted to the cockpit floor and into the balsa core!! with a bead of caulking under the flange. Not good, but because the caulking had failed, any water that got in simply drained out. On yours, the flanges are glassed to the cockpit floor. No rivets is an improvement, but I'm not sure how you can easily remove the box/coaming or get the water to drain out.
As spuncopper noted, being in a freezing environment with a failing seam like that is scary. If it weren't for freezing, I would be tempted to just build a shelf to get whatever is in the box above the possible water level.
Spuncopper,
When you moved your battery to the seat box, how did you level it? That's where I built a little shelf (for both batteries in my case). Depending on the orientation of your battery, some of the plates may be exposed (if it's a typical lead acid). You won't be getting the full AH rating. You can see from this picture that they would be at quite an angle if not for the shelf.
http://www.c-brats.com/albums/album2357 ... .sized.jpg
You can also see in the lower right hand corner of the picture one of the screws into an epoxy plug that now holds my seat boxes in place.
Mark
Spuncopper,
Mark
