Safe Windlass Operation
FX-16? I just removed an FX-11 that we never really used. It didn't
fit on the bow roller too well - the shank was too long.
Mike
I used the S/L branded (probably Lewmar now) pivoting roller on both my CDs. For the CD22, I seem to recall drilling an extra pair of holes for the pivot bolt so it didn't extend as far as the last holes but farther than the first holes. On the CD25 I have it extended to the second original holes.
If you use a pivoting roller, glue on a small piece of rubber between the rear of the two pieces so it doesn't slam hard together when the anchor comes onto the roller. I used some 3/4" thick closed cell sponge with sticky back.
I have 15' of chain at the anchor and I usually bring it up in two or three foot bursts when retrieving. I also have the flag tied onto the chain a couple feet up from the anchor so I know when it is getting close to home. While you're tying the ribbon on, it's a good idea to put a piece 20' or so from the bitter end (always wanted to use that term) so you'll know when to stop paying out the line in cases where you need to use most all of it.
And remember - the law of the sea with windlass usage is that the skipper never leaves the helm seat. You have to keep messing with your setup until you are able to perform the entire anchoring operation without any more effort than pushing the switch. Cost doesn't matter - get what you have to get to get it right.
I installed a Lewmar S/L Horizon Express (a higher geared version of the Horizon 1500) on my Sea Ray a couple of months ago and got it right the first time!
I did, however, use the KISS principle and simply hard-wired the up/down buttons at the helm.
I have a wireless remote control for winches and windlasses that I'll add to the system later this year.
I bought it so I could operate the windlass either from the helm (flying bridge) or down on the front of the boat to clear jams, seaweed, or wood debris, etc.
Actually, should be able to raise and lower the anchor from anywhere within 250 feet of the anchor or helm.
Might be useful when anchoring out and combined with a line from shore, kinda like a solid Anchor Buddy system with the real solid rode anchoring the boat, instead of the elastic Anchor Buddy line.
Anchors aweigh!
Joe. :wink:
