I've put the Katie Kat up for sale, and I'm going to be replacing the bilge pumps and float switches.
The easiest, is just to replace whats there.
The Port side was a no go. The switch was definitely bad, I haven't tested the pump to see if it'd work via a bench test. The Starboard kicked on, but not off. I suspect the float switch on that side as well.
Since I'm standing on my head anyway. I thought I'd replace both sides with new stuff. Pumps, and switches.
Hence my question.....
I noticed while shopping, that the 1100, seems to be available with an internal automated switch?, as well as just the pump, with a separate switch needed, like I have now. If this auto pump with an internal switch is a direct replacement, and would drop right into the existing strainer basket, This looks like a better idea(yes?).
Anyhoo, I was just wondering if there was a consensus amongst the Brats, as to whats the best solution.
Thanks in advance.
Gordon
Thanks in advance.
Gordon
