Hello,
I have a Lewmar V700 windlass set up with a gypsy sized for 1/4" chain and 1/2" line. I currently use a 3 strand nylon rode with 20 feet chain. This is my first boat with a windlass; all I know about them is the "up" switch is supposed to bring the anchor up.
The chain will feed through the windlass fairly well. But the line...well, that's my problem. It frequently 'hangs' up and doesn't feed around the gypsy properly. It doesn't jump off. When someone goes below and 'helps' by pulling the rode gently into the anchor locker, it works fine. I've pulled all the line out and tried untwisting without improvement.
First question: would a "Brait" type line fall into the anchor locker more easily and improve the performance of my windlass? Or, is there something else I should try?
If I buy a new rode, which 1/4" chain is right? HT vs G4 vs ?
Is ACCO chain worth the extra money?
Is all 1/2" brait the same? Is Yale Cordage worth a premium price over other brands?
If anyone has switched from 3 strand to brait, have you noticed a difference in windlass performance?
/david
/david
