Adeline
- Joined
- Nov 3, 2003
- Messages
- 985
- Reaction score
- 0
- C Dory Year
- 1989
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR2242OF989
- Vessel Name
- Adeline
This just appeared in my latest Active Captain Newsletter so I thought I'd pass it along.
Rescue Tape is a self-fusing silicone repair product with infinite uses. First used by the US Military and now seen at consumer and industrial trade shows across America, this is the most versatile and easy-to-use emergency repair product available. You can repair leaks on plumbing and hoses in a flash, use to insulate electrical wiring or as shrink wrap, wrap tool handles, and much, much more.
From the newsletter - "We have a roll of Rescue Tape in our engine room. It's there to repair
a broken hose in an emergency. Rescue Tape is a self-fusing silicone
tape - there's no adhesive. You stretch it and wrap it around
something you want to seal. When it wraps upon itself, it fuses and
makes a permanent seal. It's good to 500F degrees and has been tested
at 950 PSI tensile strength. It's the perfect thing for an emergency.
Jeff met Ron from Rescue Tape through Twitter. Ron told Jeff about
many other things that Rescue Tape can be used for. It is much better
than electrical tape for finishing and waterproofing an electrical
connection (8,000 volts per layer of insulation). And it never gets
gummy or sticky like electrical tape. It's the perfect thing to mark
anchor chain because it can be put on when the chain is wet, it seals
instantly and is available in 8 colors. It's even an excellent
compression bandage for temporary medical emergencies. Who knew?"
