removing hot water heater
The glass liner in the last tank was broken down by vibration and allowed the steel tank to corrode and start weeping near a weld. Avoid a glass lined tank for boat use. It was worth a try and too bad as it was a decent little tank otherwise.
Third times a charm. I just installed a 4 gallon Attwood marine model and was able to mount it rearward and to the side leaving usable room in the cabinet for other storage. I left the supply lines and power a little long so that it only takes minimal work and no mess to slide the tank back to access the element or other fittings easily. The valve for draining the tank is an easy reach without tools by just moving the seat cushion out of the way.
Pic here:
http://www.c-brats.com/modules.php?set_ ... _photo.php
