I want to remove the fuel from my tanks on my 23' Venture. After reading all the posts on this subject, I decided to try it simple. I disconnected the fuel line from the kicker,put a nail in the connector to keep the ball depressed and started pumping----30 minutes later, empty fuel tank[even though the fuel gauge said port tank empty and I had the fuel selector switch on starboard]. I'll address that situation when I refill. So, with one empty fuel tank, I switched the fuel selector switch to the other tank, start pumping with the same primer bulb on the fuel line from the kicker and-------nothing. No gas and the primer bulb stays compressed and will not reinflate---until I switch the selector switch back to the original position. No laughing--- but what am I missing????
