shellndanm
Any advice or tips on how to get the fuel filler hose off the gas tank. I need to remove the tanks to replace the deck.
I figured I would remove the tanks, over drill and epoxy the holes to prevent deck rot on my 2005 CD22 as recommended in numerous threads. I bought the boat three months ago. Unfortunately there was a remarkable amount of rot in the deck. I will have to replace a large portion of the aft deck. I'm going to use nida core as described by thataway. It is really sad that the builder screwed right into the balsa. It is puzzling the boat is built so well in some ways, but poorly in this regard.
I would urge anyone purchasing a used c-dory to pull a screw securing the rear hatches and gas tanks prior to purchase. FYI, I still love my boat and will simply do the repair, but I should have checked these issues closer prior purchase and would urge other starry eyed boat purchasers to do the same.
My boat was kept in dry stack with an aft mooring cover
Dan McPartlin
Dan McPartlin
