Refrig Problem CC 23
hank schneider
Mar 23, 2008
123
2006
23 Venture
Ditch Witch
Hi Folks
I'm touring the Bahamas for two weeks and the frig quit - actually it never revived after a three week layover. Is there a fuse in the circuit?? Couldn't find one on the fuse box. Is there an inline fuse on the Venture? Anything beyond that will have to wait - have cooler & Kalik - who cares anyway.
Thanks
Hank
The Norcold units have a fuse on the splice box on the back of the unit.
You'll have to unscrew the unit, and pull it out to check or replace it.
Does the unit work on 120v? If so, you might be lucky and just need a new fuse, but usually fuses blow for a reason.
Hank I have the tundra refridge (06 cape cruiser) mine had a fuse (bayonet) it was in the lazerette look there first then if you must unskrew the 4 skrews and check the wires to the fridge
I changed out my number 12 wire for number 10 and found the fridge worked a lot better also put a switch on mine so I could turn it on and off without opening fridge box Good Luck send me a e-mail if still having problem or give me a call
