When I drill a hole through the transom (or any cored material) and undercut, epoxy, re-drill, I'm concerned that unless I am lucky, the new hole won't be on the same axis and I'll end up elongating the hole on the other side, *and* potentially drilling out the side of the epoxy plug.
How do people ensure that when they're re-drilling an epoxied hole that the second drilling will match? I've come up with a few ideas, but I'm definitely seeking better ones.
1) Drill a hole through a block of something (i.e. 2x4), then hold this up to the surface when drilling the first and second time. This is tricky since it's hard to tell if the block is flat on the transom.
2) Same trick but drill with the block resting against the bit (takes care of one axis), and draw guide lines on the block (other axis)
3) Redrill with a smaller bit, then work up to the final size, making angle corrections each time
4) Eyeball it, but only drill 3/4 of the way through from each side.
For context, I partially installed my swim step, but didn't do the lower bolts yet, and I'm going to go all the way through instead of using lag bolts since the tanks are out.
