Thought I'd start a halibut rig thread I stuck some pictures in my album of a quick cheap halibut rig that's worked good for me. I needed a quick cheap easy foolproof halibut rig and ended up with this simple rig.
For $15 you can buy enough 200-250 mono line to make enough rigs to last for quite a while. I start with about a 4' chunk of line and tie an overhand knot on each end, if I'm feeling insecure or have time to kill I'll also add a crimp to the end that attaches to the main line. Next, tie an egg dropper loop knot down towards the lead end. Throw a barrel swivel on the rod end and a snap swivel or duralock on the lead end, add bling and a hook to the dropper loop and you're ready to fish.
Anchor fishing, drifting, this rig does it all and it's easy to strip your hardware off when the mono gets worn or change bling and hooks on a whim. For recreational use, you can start with a longer piece of mono and tie two egg droppers and run two hooks.
That money you've been spending on spreader bars.....you can now spend on more important things, like ............
