starcrafttom":akn322v9 said:
Greg thank you for this report.
http://maritimedynamics.com/interceptor.pdf
After reading it thru I learned a few things. 1) their test boat is the size of a cdory. 2) there was no difference in drag at all, NONE. 3) that the amount of lift was the same up to 55% of deployment of either system AND after that point the QL style tabs stopped producing additional lift while the lenco style tabs continued to produce additional lift up to 100% deployment. Now that is a big surprise to me. ( and is it lift or trim?)
Everyone go read that and then tell me what you think.
Tom, Greg, and all-
This article is very interesting and revealing.
Actually, Tom, the boat used is " a 7-meter monohull model", not a full sized to scale boat, and one hopes the model performs as does the real boat, which is always something to keep in mind, or account for. Modeling is done a lot in aero and marine studies, and the tests and results have to consider any differences in scale and how i t would effect test results.
The measurements and performance results seem to indicate the following to me:
The interceptor type plate works OK at planing speeds up to that 55% deployment point, as mentioned.
This is because (theorizing now) the vertical plate acts as a flow "dam", creating stalled flow in front of it , and the water flow along the hull flows over this wedge shaped stalled flow, pushing upward on it and causing "lift", which is upward pressure (not to be confused with aerodynamic lift, as on a wing, but more "kite effect" like.)
I thought this might be true earlier, but nowhere was their any mention of this "how it might work" theory, and the 55% figure is an interesting determination.
While up to the 55% point the drag and lift effects are similar, past that point, the interceptor plate does not produce more gains, while incurring similar drag increases like the trim tabs, but without benefit. This, in itself, defines the limits of good performance with the interceptor plates.
The trim tabs have several advantages: 1) they work over a longer range of deployment without loosing their effectiveness ("up to 66% more lift at maximum deployment", 2) they also add increased planing area (similar to that added by a hydrofoil), resulting in A) increased control over pitching (longer hull effect) and B) quicker/earlier planning during acceleration. (The last two conclusions are not from the article, but generally accepted understanding.)
There are a lot of other practical/employment considerations discussed in the article, which is aimed at large boat/ferry/ and even jet boat considerations, most of which don't apply to our situation.
So it's up to you, individually, to choose, but I think mine would be for trim tabs, and hydraulic ones at that, considering the electric motor/salt water/seals/corrosion issues. I've got Bennetts on my 22 year old Sea Ray, and they still work well.
Joe. :teeth :thup
