Minnow-
Sorry, but can't resist looking a bit at the prop choices and how they worked on your boat!
1. 14 x 19, three blade stainless-- agreed, over-propped on pitch.
2. 15 x 15, three blade stainless-- Appears to have great performance, but tumping due to clearance problems? Might try this one again w/o skeg!
3. 15.25 x 15, four blade aluminum-- large diameter and four blades = too much surface area = "grip" = too much drag and not enough slip = limited top end = SLOW !!! (but 11 mph???) Something else is going on here!
4. 14.5 x 15, three blade stainless (PowerTech)-- Best so far, but compromise...??? may have secondary feature-bow lifter?, stern lifter?, wrong amount of cup??.....blah, blah,??? Solution for this one-Call PowerTech and talk to the technical rep.- he can tell you exactly what that prop was designed for. You'll need the serial number which is etched on the hub right behind the trademark. PowerTech is the only volume prop maker that tracks individual props with I.D. #'s. (Be ready, he MAY try to sell you a new prop!)
Your 150 hp Honda may be at the bottom of the horsepower range of the Honda motors with that size hub. It would be easy to get a prop with too much surface area which would have too much drag, limit slip, and the top end.
Most people with the CD-25's find that about 15 inches of pitch provides very reasonable performance.
A four blade prop might be real smooth, and provide really nice thrust especially with the weight of the CD, but the diameter would have to be reduced to avoid the (under)slippage issue.
A 14 x 15 four blade might be worth a look, but very hard to find (15p not made in that small a diameter). The 15 x 15 three blade stainless is looking better and better.
Sorry to go on and on.. Joe.
