Yellowstone
If you are going to Yellowstone Lake (7,900 feet) go with the 13" three blade prop on a 115 Yamaha motor. My motor is the Mercury EFI 115, which is really a Yamaha with Merc. cosmetics. With a medium load I can max out at 28 mph (gps speed over ground recorded), With very heavy loads, you will need to move weight forward on your 22' and use your tabs (60%) to get on plane. Changing a prop is not that big a deal if you are not on the water.
