SEA3PO
- Joined
- Nov 2, 2003
- Messages
- 1,831
- Reaction score
- 2
- C Dory Year
- 2003
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22132D303
- Vessel Name
- SEA3PO
I have had a recurring problem....with my 2003 40hp. Yamaha twins.... they die when I change rpm... speed up or slow down... they start up easily just after they die...and they will free rev...to well over 5000rpm....but will not go up to power under a load....one goes to 4400rpm and the other 3800rpm...when they were new they easily ran up to 5500 under a load... I have had the carbs worked on three times...I have replaced both fuel filters in the motors...I have installed two Racors... so if it were only one tank or one side I would notice the difference....I get good fuel flow from the hoses...still low rpm... the motors have always had Stabil used and only have 325 hours....
IDEAS ?? Why do these things run so bad ? On the delta I ran lots of fuel cleaner through (2 tanks of fuel)...and I think it helped some...but still they won't come up to power......
I will never buy a carbureted outboard again !
Joel
SEA3PO
Joel
SEA3PO
