potter water
I've been installing pressure water for the sink in Still C-razy. I'm getting some air in the line and the only place I can't verify is on the water tank. I've opened up the tank area just under the forward facing port side seat. There is a board over the tank that makes up the bottom of the storage compartment under that seat. I'd like to see what the tank outlet fittings look like. The are in the front left corner of the tank and un-seeable even with the top cover board removed.
Does anyone have a pix of the naked tank or a model number of the tank I can look up and see those fittings.
It appears that the tank isn't secured to the bottom of the boat. It looks to be a cube tank, but it sits at and angle in its enclosure. I'm pretty sure there is a void the shape of the hull curve under the tank. I'm doing to pick up some storage just having taken that board off the top of the tank. I'm going to modify it so the board can be taken in and out to use the hidden storage behind the tank. I don't see any way to use the void that probably exists between the bottom of the tank and the hull.
Someone may have pix of removing this water tank???
