Luckly for me, I know that there is no end to some debates, and some, like spark plugs and motor oil, shouldn't be engaged in at all.
I'd been reading pitches everywhere from 12" to 18", diameters of nearly the same range, etc. My local marine shop suggested a 16-pitch. The guys at the dock got into heated arguments about whether the 13.131214 3-blade was more efficient than the 13.545 4-blade, between 2100rpm and 2600rpm, except on Saturday, when they load up on halibut. I have no illusions about attaining perfection on my first experiment, I just needed a reasonable baseline to start chucking props at, since I had nothing at all and no clues.
The consensus seems to be the aluminum, 4-blade 14 or 15-pitch on a 13" diameter. Since the pitch seems to be the "final drive gearing" part of the equation, I'm going to start with the taller gear and try the 15-pitch. I'm prepared to make adjustments up or down from there.
Also, while studying up on shaft length and such, I got a close look at my existing prop on the suzuki 100 and discovered a ding in a blade. I don't remember striking anything, but one leading edge is definitely curled. Can I pound that flat again, does it need to see the doctor, or has this prop been ruined? Is it damaging something to run it like that? I do notice a little vibration in my feet at cruise revs.
