Sundog":1l15lgbn said:
I love a latte but hate paying the 3 bucks for one and it would be fun to be able to make them.
Not only is it fun, it's way cheaper, and you can make them better than most places with about a $500 investment. While this sticker shock may put some folks off, we were buying two lattes a day @ $7 (including tip), for something I can make better, with top notch ingredients for under $1 each. So, doing the math, the machine and grinder pays for itself after 100 drinks - 3 months for us.
I've been doing this for many years, and have settled on items that work well for me. However, for a wide range of reviews and feedback, the best site for researching this stuff is
CoffeeGeek - spend some time there if you are serious about buying. For the products mentioned below, I've linked to them for further info.
So...here's my setup recommendation. It's what I used at home for about 7 years until recently, and what I use on the boat and in the RV. For lattes/caps/americanos, it's tough to beat at any price. For pure espresso, it's very good - to do better, you need to make a significant investment jump (around $1500 for grinder/machine.) Yeah...I made the jump, but quite honestly...I'd probably not do it again if starting over, as my daily drinks are lattes.
I've also added an alternative grinder selection, but it will drive the price up by about $200.
Grinder
As mentioned in earlier posts, you want a burr grinder. I don't have any experience with the hand grinders Dan mentioned...quite frankly, I'm far too lazy for such a manual contraption...
Not all burr grinders are equal. In particular, most of the lower end units can not grind fine enough for a good quality espresso shot.
- Recommended:
Solis Maestro
Note: The link above includes many older, negative reviews on the product. It was updated a while back - the current model is far superior to the old one of the same name.
Pros: Excellent grind and easy adjustability. Nice "bump" button up front so you can grind just what you need. Grind box fits very tightly, keeps the grinds from flying everywhere. Relatively compact and light - important on the boat. Cheapest grinder I've found that makes a decent grind - on occasion, you can find it on sale for under $100.
Cons: Plastic construction - with daily use, you'll probably get 2-3 years out of one before something breaks. Easy to disassemble, but tough to clean thoroughly without an air compressor.
- Alternative (more $$'s, but higher quality construction):
Rocky Rancilio
Pros: Excellent grind quality and adjustment. Beefy unit that should last a lifetime. Very quiet compared to cheaper grinders. This is the model by which most high-end home grinders are judged. Not as expensive as pro/commercial models, but a great grinder if you want something nice for the house.
Cons: Cost - around $275. Messy. Too big to take on the boat.
For strictly home use, the Rocky is very nice. For those who are opposed to the semi-disposable nature of the Solis, it's a great alternative. But...you can buy almost three Solis Maestros for the same price, with no loss in grind quality.
Espresso Machine
There's only one machine for me in the under $400 range - the
Solis SL70. Not only does it pour a fine shot of espresso, but it steams far better than anything I've used short of a commercial machine. If milk-based drinks are what you are after, look no further. With a little practice, you can froth up milk as creamy as a pro unit.
One note about the SL70 - the trick to getting an excellent espresso shot requires an inexpensive upgrade: the non-pressurized filter basket. It's a $15 item, but it makes a huge difference in shot quality, as you can use a much finer grind.
Just recently, I bought a second setup just like the above. For a Solis SL70, Solis Maestro grinder, 20 oz. frothing pitcher and a non-pressurized SL70 filter basket, I paid $519 delivered from
WholeLatteLove. These are pretty decent every day prices, but if you really search and/or find things on sale, you can do a little better.
Well...enough for one post. I'll write up instructions on how to get the most out of the above items when I have more time. It does take some practice to get good results, but it's not difficult once you know a few tips/tricks.
