Part name for the plate where the steering rod connects?
johnbenj
What is the name of the part of the Honda BF90 engine which the steering rod connects to push and pull and turn the engine? Mine is so rusty i don't think it is safe anymore and I'd like to try and replace it.
Thanks in advance
Not exactly certain which part you mean, but you might find it in one of these two pages from a 2004 Honda Rigging Guide.
Thanks in advance
If I recall correctly(50/50 crap shoot) the piece your describing is a cast steel bracket, bolted to cast steel engine swivel bracket.
To remove the two bolts & replace it might cause more broken bolt, drilling & tapping, cussing, throwing stuff & headache than it's worth it. It's a pretty substantial cast piece, I would scrape, file, sand etc. & see how much metal is there & paint as nec.
Or the 2 bolts will come off just fine & you put on a new one in 10 minutes & away ya go. :thup
tsturm":1539tmji said:
Thanks in advance
Lets try a pict http://www.c-brats.com/modules.php?set_ ... _photo.php
It looks like my memory was the wrong 50% but close, with luck & the studs instead of bolts you might get by with the bracket.
The arm is $46 at boats.net and if you figure in the cost of the rust spray and the top coat you're money ahead by ordering a new one and replacing it. You have to pull it off anyway.
johnbenj":2yghr9k2 said:
Thanks, but that is the Steering Arm Rod. What I need is the Steering Arm.
Here is a picture of mine currently:
That will Clean up just fine & be good for another 20 yrs :thup
johnbenj":2i8l6snu said:
Yakmandu":2i8l6snu said:
Looks like “Stern Bracket -Swivel Case” page.
Thanks!
005
50100-ZW1-030ZA
FRAME, MOUNTING *NH282MU* (OYSTER SILVER METALLIC-U)
1000001
9999999
$317.03
:thup
Buy a lot of paint & scraping for that :wink: & lots of labor to change.
Yup, the Stern bracket was diagram I was hoping would post. Looks like $300+ for the part. Good luck!
