Part # for BF90D high pressure fuel strainer/ filter?
Don't know what you mean by "high pressure". Please confirm you are talking about the in-line plastic filter located on the starboard side under the motor cover, just below the carbs. If so, I can give you Honda and Sierra PN's.
Jim,
1. Go to marine.honda.com/parts
2. then select service & support
3. then select parts & accessories
4. then select parts
5. plug in your engine serial number or full model number
The fuel filter you are talking about is in the Vapor Separator section of the parts and is called "screen, fuel strainer". The Honda part number is probably 16911-ZY3-010, however it is best to put in your engine serial number to make sure
Dick
