OMG, as the y0ung ones say.
Greetings fellow Brats,
I have a ten year old 24' TomCat and trailer. Needless to say, after many, and exclusively, salt water launches, the trailer needs work. Did the normal maintenance over the years, replaced springs, bearings, and converted to stainless disk brakes. Our trailer was provided by the dealer at the time and has served us well, though I admit that checking bearings and replacing springs is not a part of boat ownership I particularly enjoy.
Went to see about building a custom aluminum trailer and the first question the guy asks is "how much does she way?". Since I didn't have any idea, I figured about 7,000 lbs since my current trailer is rated to 7200 lbs. So, I took ole Molly down to the local truck stop to get a certified weight slip. 8880 lbs !!!! The scale indicated 820 lbs on the tongue and another 8060 at the two axles. Seems I have the tongue weight dead on but the overall is much higher than the rated capacity. Needless to say, I'll be getting a trailer rated to 12,000 with an in truck brake controller to head out the the Pacific NW when I retire in 3 years.
The point of all this is that I'm really interested what other rigs weigh. Now, I owned a 22' cruiser before this one and the TomCat is definitively 3 times the cruiser in size/weight. I'll never forget the first tow home after owning the cruiser for 2 years. The TomCat just seemed huge, especially since the boat is over the fenders, unlike the 22 which fit between the feeders. So, fellow 24 owners, what say you?
Begs the question what some of the 25's weigh.
Looking forward to ya'll insight and info.
I still work for a living so don't be offended if my response is slow. I have logged in very little but I assure you I check the site often. Free time is at a premium and I'm anxiously awaiting my retirement at which time I intend to be meeting many of you and exploring this glorious country like I've read about since before the Brats. I'm pretty sure I was a Dog at one time :-)
You still may be a bit over (and I think it's always good to have a scale weight), but one thing to check on your current trailer: some trailers list gross allowed weight (I.e. boat and trailer combined), and some list capacity (I.e. boat but not trailer).
If your trailer weighed 2000#, for example, and the 7000# were a capacity rating, then you'd be within the limit. May be something to consider as you shop (or decide to fix up your trailer instead).
If the 7200# is really gross rating, then yeah, you're over.
You are quite right. Ultimately what interests my trailer guy is the total weight. It will be interesting to see the weight difference of the two trailers. Granted, the new one will be quite a bit beefier that the old galvanized one. My intent with the new one is to reduce the stress on all the moving trailer parts, and it should restore my confidence in hauling long distance, not to mention making it all much safer. For the last year I've just been trailering to my local ramp.
There's nothing like having confidence in your trailer :thup The opposite can really spoil a trip (or simply discourage one from being taken in the first place).
Just for comparison, here's the numbers for the TC 255...
Weight of Ford Excursion Diesel Tow vehicle #7120
Total Weight of TC 255, 3/4 fuel/water, no people but all accessories including trailer #10280
Trailer Weight Empty #1900
Boat Alone (do the math...) #8380
Tongue Weight #1280
The Captain sure has it together. And just the kind of info I was looking for. Gives me incentive to respond in kind once the new trailer is built. In the meantime, I went and looked at the tag on my current trailer. GVWR is 7460 lbs. GAWR is 3750 at each axle. That's all the usable info on the tag and still puts me way over. Original weigh was with full fuel, water, 1/2 head waste, air conditioner, generator all the gear but without coolers, and personal items. I'm looking forward to the new trailer build. All my past trailers have been galvanized and I've always heard that aluminum is the way to go in Florida. Time and experience will tell.
Looking for more trailer/boat weight info as time goes on so please share what your personal situation is. I can see that I may be placing a lot more emphasis on what and how much I carry in the future, especially with the long tows between my intended cruising grounds. And from what I hear on this site, the rig and boat may also be the camper.
That trailer at 1900# is an aluminum Float On trailer. I had a galvanized one too for the other TC I had at the time. It weighed about 400# more. Both had hydraulic surge brakes.
