- Joined
- Nov 2, 2003
- Messages
- 8,561
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
We just crossed 20 hours on the new Suzi 200, and so it was time for the first oil change. I went down to Clearwater Marine in B'ham and purchase a couple of oil filters, the filter removal tool, and two gallons of Suzuki Ecstar oil. Then I fired up YouTube for a video on Suzuki oil changes. I enlisted my brother in law, Berry Ruden, owner of Crabby Lou, to assist.
The first video was for a Suzuki 350 and I assumed the 200 would be the same, easy-peasy. Wrong-o! Draining the oil is the same on both engines, but on the 350 the oil filter is sitting upside down right there and accessible as soon as the cowling is removed. On the 200, the oil filter is buried behind the skirting below the cowling. Another YouTube confirmed that the skirting had to be removed. There are six bolts that hold it in place, and some of the heads are in deeply recessed channels. We finally got all the bolts removed with a nut driver set that I gave Patty many Christmases ago.
But with all the bolts removed, that sucker did NOT want to come off! We pushed, we pulled, we whacked it (carefully), but no she go. So we first called Sportcraft Marina and then Tyboo. Both John at Sportcraft and Mike assured us that it would come off after removing those six bolts, and we should not be timid or gentle with it! We followed their advice, fearful of breaking something, but FINALLY it broke loose. It seems there is a seal under it that it tends to stick to the first time it is removed. That seal has now been liberally coated with petroleum jelly. It SHOULD be easier next time!
The photo below is what we saw when the skirt was removed. The filter was then easy to remove and replace. We put the skirt back on, and poured the oil in the top. Two gallons took it right up to the top mark on the dip stick.
