Otter: Yes, I feel like your rig will haul the TC. Yes, launch and recovery is a bit overwhelming at 1st, but, once you get use to the "process"... I have both launched and retrieved mine by myself. It is way easier with 3 folks and a lot less going to and from areas when alone. Basically, I have learned to leave a lot of the trailer exposed above water as to "catch" the boat and align on the trailer, particuarly in wind and or currents. Then, crank up the wench or drive the boat forward (wench if your are alone, motor if you can stay on board), then, when whenching gets tuff, or moroting meets resistance, back her back into the water a bit more, wencher up some more, back back a bit more, wench her up a bit more. Launching is way easy....just be sure to have a long enough rope to attach to the cleats on both front and back end of the boat in high winds/current. Just one up front makes the boat come back to shore...oh...but that back end takes off without the help of the aft rope. Yes, I plan on getting one of the 6' trailer tongue extensions Les told me about on day one.... Just to keep the back end of my low Excursion out of the water.. during this wench-n-backing process. Yes, it is a bit more at the ramp than with my 16, but, being at gatherings seeing other folks launch their 22s... I do not see a lot more to it....once you get use to it. Each time I have loaded or unloaded the boat, it has been easier. And...only once have I had a 2nd person to help me who had seen and been a part of the process...so, it ain't hard to get someone to sit in the cab and back her back down in increments for loading. Launching sort of works itself out...other than jumping out quickly if the current/wind takes her off the trailer rather than getting back there and pushing her off.
Jeff and EZ-Loader are both working to fine tune the current trailer set up this week I believe, and, the trailer vertical highth can be let down some. It appeared to me that EZ-Loader started high as to give themselves material to work with/take out if needed to lower the boat. THis should be one fine rig.
As for the towing weight, mine pulls fine with the cruise control set on about 72mph with the 2005 Excursion w/6.0 turbo-diesel. Yes, towing her around town warrants a bit more care particuarly watching for those little sub size cars that dart in front of you at red lights to fill that nice safety margin or room you had to ease into a stop. Yes, I have wanted to nug them little suckers at times...particuarly the ones on the phones... I do think I will look back at my annual trailer boat magazine issue with the towing guide in it. I keep my vehicles for many many miles, and if I can make it easier on it, then it will be easier on me...and the equipment. Each tow vehicle is different, as hauling safely with each new set up is different, and needs to be addressed. All way do-able .
