I know, another prop question. After many years of using the stock prop on our Suzuki DF90, which is the 3x14x17, I've decided I want to try a new prop. The current prop is on the bottom end of the RPM's at WOT, 5200. Our boat is usually moderately to heavily loaded, with minimum 2 people. Just the other day, we brought the boat up to around 5000 RPM and were getting about 24 mph on flat, smooth water. The last test I did recently was 5200 @ 26 mph WOT. This is lower than we used to get when the prop was newer. I believe we achieved 29-30 mph @ 5200 RPM WOT lightly loaded on flat water, several years ago.
My question. I'm looking at lowering the pitch to get additional RPM, the range is 5200-5600. It seems that most of the choices would have me drop in diameter to 13 3/4. I'm either considering getting a 3 blade 13 3/4x15 pitch. Would the drop in diameter by 1/4" have a noticeable affect when dropping the pitch 2"?
I'm also considering getting a 4 bladed prop. If I decide to do that, should I stay with the 14 x 17 or also drop down in pitch to 15?
I'm depending on the guidance from the prop gurus on the site to help me with this dilemma. :wink
