- Joined
- Mar 3, 2005
- Messages
- 3,599
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBD
- Vessel Name
- journey on
I'm trying to install a Navman Fuel 3100, and I know several people have them and they work. So, my question is:
To hook up the NMEA in (GPS output, 3100 input) signal the Navman manual shows a single NMEA in signal (white wire). My GPS outputs NMEA data on two wires (NMEA out + and NMEA out -.
The Navman manual also shows the NMEA ground (I assume it's also power ground) going to the battery. The GPS also has a NMEA data ground, did someone connect it to the 3100 ground?
Given that plethora of data, how did you hook up the meter? Single ended or somehow differential?
Help, Boris
Help, Boris
