I was camping the last couple days on my 22 Classic Cruiser with twin Yamaha 40's. I rebuilt the carbs and increased jet size because of previous issues with these motors many know about. I have taken the boat out many times and its ran great but I had a strange issue happen when I took it out and started the port motor this trip.
I primed the bulb to the port motor and it didnt seem to have too much pressure so I pumped it quite a bit around 7x until I could feel pressure in the bulb.
When I started the engine it wouldn't start initially and i could barely get it to run extremely rough and knocking with the throttle speed all the way up. I went out and stayed close to the marina motoring off the starboard motor which was running fine. I tried to start it a couple hours later and same symptoms-it would run in neutral with throttle high extremely rough and would die as soon as I put it into gear to try to get propulsion from it.
The next morning I launched and figured I'd try to start it to see what happens and it started right up and sounded great and ran great all day.
I"m thinking. Did I potentially flood it that badly where it needed to rest that long? Maybe I should have just kept running it rough until it cleared itself out when it was having the symptoms.
Maybe I had water in the racor filter/fuel water seperator and when I pumped gas at that velocity through the bulb it took some of the water with it and that was causing the engine to run so rough?
Any ideas?
Any ideas?
