potter water
- Joined
- Apr 12, 2011
- Messages
- 1,076
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- R-21 Tug
- Vessel Name
- Poopsy
A. Get a three quarter ton (at least) diesel, ford, chevy, dodge...doesn't matter. They are all good.
B. Tow ratings are only good for cutting in half. If you have a 10 grand tow rating, then assume that you are maxed out at 5 grand. That way your tow vehicle will have a good long...normal...life span with breakdowns a non issue. Oh sure, you can tow at max, but the life of the engine and xmission will be half or less than you expect and you WILL break down at the worst possible locations.
C. Tow at low speeds. I'm a maximum 60 mph towing anything, my fifth wheel, my sailboat or my CD22. There is not much that can go wrong at 60 mph that the big ol' diesel can't recover from...blown tires, etc.
D. Mileage will be better than any gas engine, usually enough to wipe out the diesel/gas fuel cost difference. I get 20 true MPG empty, 15 true mpg with the CD, and 11 True MPG with the fifth wheel at 60 mph.
E. The more truck, the better.
