David-
Found it:
HERE
Here's the test procedure itself:
Tom-
OK! Now we know where to go next!
Check to see if the terminal and wire going out of the switch are "hot" with a light bulb type continuity tester or voltmeter when the switch is in the automatic position. If they are then...
Go the pump and check that the incoming wire is hot there. Also, there could be a fuse in the line between the switch and the motor, so if there's no voltage at the motor, back up and check the wiring and possible fuse between the switch and the motor. The fuse and fuse holder are the most common source of trouble in these systems. Some corrosion can be cleaned out, sometimes it's necessary to replace the fuse, sometimes the fuse and the holder. Diaelectric grease can help seal out moisture and salt air that cause problems.
If the wire(S) to the motor(s) is hot then lift the float switch(es) manually to see if the motors come on. If theY don't either the switches are bad, the motors have problems, or the wire to the ground is bad.
The float switches can be external, or internal within the pump bodies. You'll have to raise the swithces and see if the power passes through them. Checking the emerging power may be difficult to do because the wires are shrouded.
If the pumps don't come on with the floats raised, I'd jump a wire to a good ground and then see if they come on, again with the floats up. However, if the pumps work on "Manual", the motors and the grounds should be OK, and the problem is back before the motor:
Switch...line...fuse....float...check 'em out in order!
If this doesn't do it, you'll have to remove the pumps and work on them on a bench where you can hot wire them directly and see what's going on inside.
Keep me posted on what you find out !
