AK Angler
- Joined
- Nov 18, 2003
- Messages
- 327
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 26 Venture
- Vessel Name
- Rod Holder
OK- I know that the little Anglers are designed to hold up to 3 portable 6 gallon gas tanks. That fact, however, did not stop a previous owner from mounting a single 18 gallon tank athwartships, under the splashwell on Navicula. (It also has not stopped me from loading up on extra gas cans when I need to...) I grade the tank installation a "C" for resourcefullness and an "F" for application.
Here's why:
1. The tank blocks access to the recess where the bilge pump resides. At this time, I can't even remove the pump if I wanted to (or if I HAD to).
2. In order to avoid removing the bilge pump altogether, the tank was raised a couple of inches on wooden blocks. This gap readily collects all kinds of debris, and is a royal pain to clean under.
3. The tank also blocks the drain hole and plug. I can barely squeeze my arm under the tank far enough to reach it- and I had better not be wearing long sleeves (see #2 above).
4. The tank is black, which necessitates using an electric fuel level sending unit. While I'm not opposed to reading the fuel level on the dash mounted guage, it's one more system on board that shall be governed by Murphy's Law.
So- I am removing the offending tank. That much is a done deal at this point.
The question that I have for my fellow Brats (especially those sporting 16 footers) is... How much fuel is too much?
The replacement tanks (yes- tanks... 2 of them) that I am llooking at using are "saddle" type tanks that would get mounted under the sides, where the foam blocks currently reside. And I am leaning towards a pair of 24 gallon units made by Moeller.
I figure that if I get a couple of big tanks and mount them out of the way, it would be better than getting smaller tanks (Moeller makes 18 gallon versions of the same tanks). That way, I wouldn't have to carry gas cans (which seem to always be in the way...) when I need more fuel.
I know, this begs the question.. Why do I need so much gas? Well, I need to have a realistic range of about 150 miles, not including any reserve, to make the trip out to my property on Latouche Island from either Whittier or Seward. At ~4.5-5 MPG, I figure about 45 gallons would do the trick.
One more thing to keep in mind is that the Whittier Tunnel Toll Nazi's don't allow any more than 10 gallons of fuel through the tunnel in gas cans. Any more than that must be contained in gas tanks. They do ask. I have not yet been inspected, but I hate lying to them.
So, has anybody mounted saddle type tanks in a 16 footer? What size? Also, What will be the effect of moving that much fuel forward a couple of feet?
WOW! this post got REALLY long didn't it? SORRY...
Here's why:
