Johnson (Suzuki) 90: Another midsection corrosion failure
Hoo-boy. Got a call from Jacobsen's today. They wanted me to look at the Engine Holder casting. The one we replaced in 2008 because of corrosion around that inspection port? The one I talked about in the other thread back in 2008? THAT one!
So I stopped by to look. It has corrosion...not enough to break through, not yet. But when it does, it will be on the INSIDE, not the outside. So when it fails, it will not produce the "engine running rough because it's starved for oxygen because the engine compartment is filled with exhaust" problem. No, if it fails where it seems likely to, it will produce a DIFFERENT problem. Let's call it the "exhaust and seawater mixing with the engine oil and completely destroying the engine" problem.
So, yeah, as long as I'm already spending $1000 in labor to replace one midsection casting (Oil Pan), I've decided we should spend another $1000 to buy an additional midsection casting (Engine Holder) to ensure we don't accidentally destroy the engine in a year or two or three.
Not happy about it, but reasonably happy that Jack at Jacobsen's took the time to inspect it carefully and call me when he spotted the thin wall.
Once I get the part home I intend to put a caliper on it and measure the wall thickness there. My guess is that it's 1/8" or less, as opposed to the 3/8" or so elsewhere.
Heck, it might last three or four years without breaking through, but my fear is that I won't have any idea that it's failed if it breaks through at the beginning of a long run. I'll be leaving an oil slick behind, and the next time I check engine oil (which is every day when I'm running the boat), the oil won't be pure oil, I'll know what it is, and my trip will be over, wherever I happen to be.
But what if I've run the boat for 3 or 4 or 5 hours before I discover it? How much damage will I have done? That makes me nervous. So $1000 now for a fix I know I'll have to do within the next couple-few years anyway, saving the $1000 labor cost because I'm already incurring it for the CURRENT repair? I think it all pencils out. Do it now.
Feedback? Could I reasonably have waited? Am I overestimating the risk of waiting? Thanks, as usual!
Hi Tim,
Sorry to hear that - especially since I have the same motor including year.
How many hours on yours? I do believe your motor has seen more saltwater than mine but not sure if that makes much difference.
I have not seen a problem yet but I cannot remove the steel plug to replace it with the aluminium one.
I hope this is the end of these problems for you after the repair is done.
Steve
I hope the new parts are better than old
We had similar problem with Yamaha OB and the new parts looked like a coating or glaze was applied
best
SeaSpray":2gualtku said:
Hi Tim,
Steve
Yes, I've been equally concerned about our 2006 Suzuki DF90. I was able to remove the steel plug this past spring with ./8" drive hex bit socket. Then I replaced with the aluminum one found on Ebay. I didn't see any noticeable corrosion on the outside or inside but I guess you never know. I'm hoping the fact that we kept C-Dancer dry stored at Twin Bridges for 7 out of the 10 years helped to stave off any destructive corrosion. Fingers crossed.
Here's what worked for me:
Ace Hardware 3/8" drive hex bit socket
Sorry to hear about the expensive repair Tim but it sounds like this will do the trick. Good to know that Jacobsen Marine repairs Johnson's (Suzuki's) since they're building a new facility right across from the Edmonds Marina.
From reading thru this entire thread again, it amazes me that there is no recourse to owners. I mean a design defect/mistake/F-up (call it what you want) is just that and the manufacturer should make good to their customers IMHO.
Sorry to hear the expense, Tim. Unfortunately, I know how you feel....
Yamaha called me about the corrosion issue for my OB.
It was out of warranty. sorry we cant help
Story was published in BoatUS by Charles Fort
SOme attorneys got involved with a class actiion suit. I didnt join bc no one locate the smoking gun that Yamaha knew about the issue early one but mechanics going to training got a different story and training on how to fully repair mid section corroisin issue. It costed me $3K to repair compared to repower with Suzuki 250 or 300 with fly by wire controls and otehr gizmos. I had it repaired
Oh well, life is full of ups and downs, and I did not let this rain on my parade. It is doubtful I will re power with Yamaha if that days comes. It runs like new now. Very quiet, very reponsive and WOT is 5800 rpm (6K limit)
Best
I should point out that the NEW corrosion on the NEW (2008) Engine Holder casting (the one WITHOUT the troublesome inspection port/plug...the port cast shut as monolithic aluminum) does NOT have corrosion at that site. I'm seeing corrosion elsewhere in the casting. I'll post pictures when I get a chance.
