inside overhead CD25 rod holders
breausaw
In the process of installing overhead rod holders in the cabin. What has been holding me back is I'll need to remove the stereo from the shelf above the helm; I'll need the extra forward space to accommodate rod tips.
Replacing the stereo with a simple AM FM with Bluetooth and USB plugs will be another project.
I figure my long down rigger poles will mount to port so not to interfere with the bathroom door then store the shorter halibut type rods to center.
The plan is to fabricate brackets to attach to whatever rod holder I use and secure them to the top rail mount screws.
Having the ability to store the fishing rods in the cabin when not in use will be a huge convenience for us.
So in doing the math and making a few measurements I figure I can store 6 fishing poles out of the way against the ceiling of the cabin.
I've got a pretty good to fair idea how I want to approach the project but would welcome any constructive criticism or ideas. In looking through the albums I've yet to see anyone with overhead rod holders but I've only looked at a few dozen in search of pictures.
I have seen guys use lengths of pvc pipe for rod holders. Measure the dia. you will need to fit the largest eye(closest to reel). Just the reel and handle stick out and can be supported with a Velcro strap, small bungie, etc.
Don't know if this would work for you, usually I have seen them under the gunwales or in floor locker.
Regards, Rob
Check out C-Critter pictures mine is only for three poles but could do more then one, one end is split and hinges down. 3M 5200 holds it in place very solid.
Richard
I used 2 Berkley sets @ $15.00, thru bolted, 5200 sealed,
holds 4ea 8.5' salmon rods & 4ea 6' Butt rods.
These are what I had in mind attached to flat stock or aluminum channel then anchored in place using the existing top rail through bolts.
Like the looks of the Berkley install but want to avoid adding additional holes in the cabin roof, could make them work perhaps.
The Trac-A-Rod Fishing Rod Storage System holds promise.
I used 5200 to attach my shelves behind the galley so I know it would work for the rod holders. A little hot glue to hold in place until the 5200 cures and its permanent.
Thanks for the feedback.
My boat came with the Trac-A-Rod system on each side of the ceiling. It is simply screwed into the roof core, not thru bolted. It is nice storing the rods inside, I must say. You can adjust each piece with an allen wrench to allow for spacing of rods. I use two piece rods and they store just fine.
Dora~Jean":doxmpke3 said:
If you go to my photo album, you'll see my overhead rod holders. I think I can hold 8-10 (will have to count), but they've worked great for all the years I've been using them. I like the extra spaces for when I have friends come along, they can put their rods nicely out of harm.
http://www.c-brats.com/modules.php?...ame=gallery&file=index&include=view_album.php
(Sorry, forgot how to do fancy embedded links...)
Nice, do you know the name of the brackets?
Also like how you held it in place while the adhesive dried.
Breausaw;
I installed a 6 rod rack in my Tomcat. I made the mount out of teak and used Taco rod holders. Teak blocks mounted to roof with 5200 adhesive and screwed teak board into blocks to hold taco rod holders. There are pictures in the reefmadness album. They came out very nice and I used them the way that you describe you want to. For long downrigger rods and halibut gear.
Gene
I screwed the rod holders down to strips of oak then used 5200 to get them to stay on the roof of my trucks cap. Most of the fishing outlets carry something like this setup. Powder coated steel I believe. The coating is pretty thick as there doesn't seem to be any sharp edges. On the V'd end where I put the rod tips I use a rubber band to make sure they don't bounce out if we have to do any Duke's of Hazard type stuff.
D.D.
Gene Morris":s6xa9h01 said:
Breausaw;
Gene
Gene,
I like the use of teak and that you used the same rod holders I had in mind. I think the Taco rod holders have a clean look, you get what you pay for.
Gene,
Just have to say Dawson is one handsome fellow!
Our Sunshine, 1 1/2 year old Golden, could be his sister. She loves to boat and makes friends everywhere she goes, too.
Nothing like a Golden for a your dog, they're the best!
Patrick
Finally got around to installing the rod holders so figured I post some pictures; took a lot of thought and measuring. My down rigging rods are way too long for the cabin so had to break them down. The reels are pretty heavy when combined so just opted to mount the butt ends on top of the overhead shelve, this moves them forward as much as possible. The tips are light by comparison so just used some aluminum flat stock bowed a bit to match the curve of the cabin ceiling. Attached this with a bracket fashioned from aluminum angle attached a top rail screw. Had to offset this a bit because of rod length plus didn’t want anyone getting stabbed in the eye when entering the cabin. Rod tips don’t inhibit head door either.
Happy with the way it turned out, look forward to seeing how it works on the water in a couple months.
