Hi we've been putting on some miles lately. I have wondered about a slight oil sheen off the transim that I thought must have been the preserving fluid my mechanic uses at service as all the steering components looked tight and drip free. Did an overnight in the harbor and a tour this am. The steering started to feel very soft and needed more than nomal turns then it stopped moving at all. Turn lots no steering. Wind nw 20 as usual. Got thru the anchored boats and dropped the hook in the clear. The dteering ram was pouring fluid out the end seal. It tightened easily. And needed to refill fluid from spare on board. Opened the bleed screw one at a time and shortly started to see movement back there. Still feels spongy but works. Going in for 100 hour interval service this week so will purge the steering well. Check your end caps on your ram. It is a flat plate with 4 holes to acept a proper tool. I found my davis fuel fill wrench to fit perfecty to snug up. George
