kcassal
- Joined
- Mar 3, 2022
- Messages
- 26
- Reaction score
- 1
- C Dory Year
- 2008
- C Dory Model
- 26 Venture
- Vessel Name
- Sea Slug
Hello, I have a Venture 26 (Cape Cruiser) with a 2008 King trailer. I've already replaced the 4 disc brakes and the electric over hydraulic actuator. I'm noticing that my line from the actuator is losing its protective cover (from UV I suspect).
Do folks typically replace all the lines on a regular cadence? I'm wondering if a tandem brake line kit would fit this trailer.
This one looks like it might: https://www.fisheriessupply.com/dexter-brake-line-kit-tandem-axle/k71-g02-59 ???
Alternatively, perhaps I should just fix the long line from the actuator to the rest of the system. The flexible rubber lines seem to be in good shape, but this long stiffer line is starting to fall apart. If I go that route, what a good way to source a proper line to run from the actuator back?
Thanks!
Thanks!
