JamesTXSD":dsflpwvr said:
I like the idea of a U-shape dinette with a table that can slide out into the aisle... not an uncommon use on RVs, especially Class Bs.
I like the idea but I still haven't figured out how to make it work in an 8.5' wide boat. In an RV you don't lose a foot to the side decks, and a foot in this case is a big deal. It really takes about 48" to make the u-shaped dinette work and if you use that for the u-shaped dinette then you've only got 18" left for the passageway by the time you leave room for the starboard side deck and galley/helm. An 18" passageway is doable but tight (and it has to be offset to starboard).
And while we're on the subject of RVs, make the cruising boat more like an RV: put the water switch where you USE the water, not on the front panel. Put bright lighting over the galley and dinette. Make the showerhead functional (not a toilet sprayer) with a decent flow blocking switch so the water doesn't go cold between sprays. Make the head door NOT leak when using the shower.
Good thoughts!
Put the Wallas (or other stove top) to the side or mounted back further to better utilize the limited counter space.
A Wallas works better when it's mounted further back on the counter. When we've done that in the past the complaint is that we used up all the good space at the back of the counter for the Wallas and the space in front of it is useless. Now we ask folks to tell us where they want it when we install them.
Put a pull-out faucet/sprayer on the sink. Better storage (racks) under the galley. A smaller water heater to better utilize storage. Make an inverter a factory option. Make the boat "turn key" for cruising, and those who want to cruise will be drawn to the boat.
Well, considering that each Marinaut is built one-at-a-time for each customer and that we're both the manufacturer and the dealer folks can have just about whatever they want as a "factory option". We've long been known for delivering fully cruise-ready boats so it's really no different now.
Consider a "fishing option" for those who don't need all the cruising amenities.
That's really the standard boat since standard equipment list will not include all the cruising goodies, which we can add for folks that what them.
Most of the above suggestions would cost very little if designed into the boat. I truly appreciate the fact that you are soliciting ideas from the folks who would be your target market. :thup :thup
Thanks Jim. I'm really trying here.
The biggest challenge so far is the "concept" of the Marinaut 25. So many folks seemed to like the C-Dory 22 but wished they could get it with a head compartment, and they didn't want something as big and as expensive as the C-Dory 25. Now that we have the Marinaut 215 that's what I'm trying to offer; a M215 with a head compartment. I'm trying like the dickens to keep it light and simple to keep the price down, to keep the power requirement down, and to make it available to more tow vehicles. If I add everything that the C-Dory 25 had then we're right back to having a larger, heavier, more expensive boat.
I guess the most difficult part is visualizing all this. If we could set the three boats (the M215, the CD25, and the M25) next to each other the sense of size that you'd get from each would put them in the order of (smallest to largest): the M215, the M25, and the CD25. The M25 would look small next to the CD25; it's the same length but it's not nearly so bulky or tall. All we're really doing is stretching the M215 out and giving it just a
little bit more height to keep it in proportion. We're also making it 6" wider but you can really "see" that when looking at the boats in profile.
So rather than thinking of the M25 like a CD25 cruiser it should be thought of as a Marinaut 215 with a head compartment. It's not my intention that it compete directly with a CD25. It's not going to come with shore power, a refrigerator, water heater, and all that stuff. That can all be added (heck, we can do that on a CD22 or M215) but it isn't part of the standard package. The M25 will be for folks that want simplicity, light weight, and good economy and don't want the weight, cost, and complexity of something like the CD25.
Someone tell me if I'm missing the whole thing here. Is there an interest in a boat like I'm describing (especially from CD22 owners) or is everyone wanting an alternative to the CD25 with all that implies (all the cruising stuff)?
To help you help me...if we make the M25 a full on cruiser with all the cruising goodies standard we're talking about a $120K boat (fully loaded with electronics, etc) and not something in the $90K to $100K range.
Les
