Robert H. Wilkinson":3pm4jyr1 said:When I get out into open water away from other boats I usually give my horn a short test blast every time I go out. This helps keep it from seizing up and comfirms it is working.
Regards, Rob
hardee":xpx3pja7 said:It is also acceptable practice, though not used often, to do a 1 second horn when leaving a slip, or slipway and entering a fairway, when visibility is hindered.
hardee":exhkctbf said:It is also acceptable practice, though not used often, to do a 1 second horn when leaving a slip, or slipway and entering a fairway, when visibility is hindered. Don't be shy :? or obnoxious![]()
SleepyC:moon
dotnmarty":346t5dyo said:hardee":346t5dyo said:It is also acceptable practice, though not used often, to do a 1 second horn when leaving a slip, or slipway and entering a fairway, when visibility is hindered. Don't be shy :? or obnoxious![]()
SleepyC:moon
I used to do this routinely when leaving our slip at Everett. Visibility at the main waterway was blocked by large boats tied to the very end of the long dock. One day, as was my practice, I gave a blast out the window on a hand held air horn. This liveaboard guy came up on deck and proceeded to holler at me for interrupting his nap!
