Our 2006 Honda 90 hp outboard has some serious ethanol related problems. It was squirting gas out of the cowling and running very rough when we tried to start it 3 weeks ago. We are NOT mechanical, so took it in to a local shop in Des Moines, Wa. They had it for 3 weeks, cleaned the carbs etc, and said it was still running rough, they couldn't find the problem (maybe a sticking valve?) Had lots of gunk everywhere and our gas in the tanks smelled and looked "bad." We filled the tanks in Nov with Chevron gas, used the blue Stabil. The motor had issues with stalling at low rpms while trying to get up on plane, then did fine at higher rpms. We were told we probably had clogged fine jets in the carbs. Tried Seafoam to see if that would help, and it seemed better (before putting away for the winter). This is sounding scary-bad now. I contacted King Salmon Marine in Tacome, Honda certified mechanics there. They have a 3 week wait list. Can anyone recommend a good Honda mechanic in the Seattle or surrounding areas? Does it sound like our engine is toast or maybe salvageable? We are having serious heartburn!!!
Appreciate any feedback and recommendations for service center.
