Active member
- Joined
- Nov 7, 2003
- Messages
- 7,959
- Reaction score
- 2
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
I need some help with my wash down pump. I want to do two things and need to know if one of them will work. I would like to connect the wash down pump up to my fresh water system so i can rinse with fresh and not salt. I also want to connect to the sink so I have water there. The pump is a Shurflo marine blaster with a flow rate of 3.5 gpm. with a pressure setting of 45 psi. Is that to much for the sink fausts to handle? My other problem is where to put it. I was going to put it behind the water tank but the out let for the tank is on the bottom and facing the center of the boat. I cant even see it at this point let alone plumb new lines into it. Now sark says his is under the sink area. My concern with that is my compass head for the chart plotter is under there to, right on the back wall of the cabinet down near the door. if I put the pump, with all its magnets, up toward the captions seat then they are close to the fish finder brain under the helms seat. The auto pilot brain is back by the compass. I just do not know what bad effects the pumps motor will have on all these things. Any idea????
