tparrent
- Joined
- Dec 23, 2009
- Messages
- 285
- Reaction score
- 0
- C Dory Year
- 2017
- C Dory Model
- 255 Tomcat
- Vessel Name
- Tomfoolery
As easy as I have found the CD16 to tow, launch and use, one thing still bothers me - fuel. As a longtime sailor with diesel engines, I haven't had much need to fuel up and no need to use plastic tanks.
I keep two six gallon tanks on the 16 - both fitted with quick connect fuel line connections (I tried refilling a tank on the lake once using a spare tank - never again). These tanks bloat, hiss and leak - and that's before I even launch the boat!
I think I would like to have a good sized tank (20 gallons? more?) with a deck fill pipe. I would prefer a vented metal tank.
I don't know if any stock tanks are available that would fit the 16. I am also not sure if the tank should be positioned in the bow or stern. It seems like the bow would be a good location as it would be out of the way but I imagine installation would be more difficult (for the installer - I would never attempt such work myself). Putting a single tank in the stern could also present problems with the bilge pump. I suppose I could have two tanks installed but then I might have balance problems.
Speaking of balance, where do people have their battery installed? Mine seems to be in the worst possible location - starboard side, stern. Since I nearly always go out solo, the battery placement just amplifies the inherent trim problem I have with me sitting to starboard.
Thanks for any suggestions
