Has anyone with a Garelick bracket experienced corrosion on the lower part of the mounting frame below waterline? I can't say I am surprised knowing that aluminum and salt water seldom get along but it only has been 3 months since I installed the bracket and at the present rate of corrosion don't see much of a future for the bracket. Is there a protective coating that can be used?Or, should I look into adding a zinc anode just like on the the main motor bracket? ( by the way that one zinc took a heavy toll as well during the same period of time) Thanks for any idea and input.
Alain
Alain
