crowleykirk
Hello Brats
Hope you're all having a great summer.
I've run into an issue and an extremely poor design flaw IMO, on a new C-Dory 23 Venture.
Been smelling gas in my starboard battery box and at the back of the boat for awhile now and could not find the issue. I did have full tanks vent fuel out the fill inlets and cap, ran down the side of the boat and wrecked the pin striping and silicone seal. So if your tanks are full and it gets hot, they will spill out fuel. Just FYI. Obvious fix for that. I had no choice with full tanks at the time as I could not get the boat in the water. Some of you know the story.
She is home now and headed to Newport Beach next week. Yeah.
So once all that was cleaned up I still had the small. Removed the starboard battery and found trace amount of liquid fuel in the battery box. Yep, actually fuel.
In a battery box. The same box with all the battery connections and switch. You heard that right. There are (2) Fuel Vent Emission Manifolds.... in the battery boxes, one on each side.
There are a few connections that are double clamped. Of course I checked all those and one was slightly loose but no signs of moisture. Cleaned it all out and ran the boat again yesterday. Still smelling. At this point looks like the Manifold has a slight leak. Getting ready to take it apart again today. I have talked to the builder and I'm working with them on it. They said the entire system is pressure checked before it leaves except one hose that their tester goes into. Makes sense. Checked that one. Good.
So, we might need a new Manifold. OK, no biggie.
But.... what the HECK is ANYTHING that can possibly leak gos vapor into our battery boxes... doing INSIDE a battery box in the first place? Seriously????
Gas vapor is more dangerous that liquid gas. One spark... and boom. Done.
I'm super concerned with this and of course wondering if this is just a Venture series issue or the rest of the line up as well and has anyone else had this issue? NMI says they have never seen the issue. Hmmm.
This is a MAJOR and dangerous design flaw if you ask me. They could build a box outside the battery box to house the Emissions systems.
Thoughts?
Thoughts?
