Steamboat_Willie
I have a question regarding an issue I have with diesel fuel emerging from the fuel vent on our R21EC. We've discovered that when we are sitting at anchor out on the water with the boat rocking (gently) back and forth we will get some residual diesel fuel that will spurt out of the fuel vent opening as the fuel in the fuel tank has the opportunity to slosh back and forth in the tank. When the movement 'timing' is right a small amount of diesel will surge out of the vent and splash on to the flat surface along the transom. As we keep cleaning it up with a paper towel throughout the day the boat smells more like an 18-wheeler when it is time to motor back to the dock. And it has stained the fiberglass at the transom as well.
Obviously I'm motivated to have a full tank of fuel before leaving the dock. So I guess it's not unreasonable to expect some fuel to emerge from a fuel vent under these conditions. But I'd like to contain it and prevent it from making a mess as it does when were sitting idle at anchor. And I don't want to even think about encountering some over zealous marine policeman on patrol who cites me for an EPA infraction if he sees even a tiny little oil sheen by my boat.
Does anyone have any experience with this issue and if so how did you solve this inconvenience? Comments appreciated.
Thanks.
Ed
Thanks.
Ed
