Fairbro
- Joined
- Nov 2, 2003
- Messages
- 313
- Reaction score
- 0
- C Dory Year
- 2001
- C Dory Model
- 22 Cruiser
- Vessel Name
- Minnie Swann
This problem has occured 4 or 5 times in the last season. The boat is left in the water for the season. The cockpit is constantly covered and so are the filler caps. The carbs were rebuilt by a highly regarded shop after it happened the first time. It happens in both warm and cold weather. I get fuel from several sources and mostly marinas. Shortly after starting the 2 Honda 40's one of them quits. It will not restart. I disconnect the fuel line and bleed off a pint or two of liquid that looks like cloudy lemonade. I re-connect the fuel line and restart the motor with lots of choking, killing and short running before it works its way out and runs fine for several trips. Fill caps and vents are tight and waterproof. The cloudy lemonade like liquid turns back to a crystal clear orange gasoline after sitting for awhile. Everything runs great for a few weeks and then strikes again. I always fill both tanks at the same place and time with the same amounts. I have used isopropyl alcohol on two occasions. I know about condensation but this is the first time in 5 years this has happened under identical storage conditions. The one thing that has changed this year is I raise the motors after use now. Any similar cases or solutions?
